Status: Open
Status: Answered
Status: Closed
Status: Duplicate
AppWorks - Connection to OTDS failed to initialize
Posted Feb 05 by Ashvini Singh.
Updated Feb 05 by Marcin Pacyga.
Hello,
We have installed OpenTest TempoBox 10.1.0.
We want to connect AppWorks gateway 1.1.6 to existing OTDS using option "Contect to existing OTDS server" but while saving changes,
it is throwing following error.
We are using following versions of software components.
AppWorks gateway Version : 1.1.6
OTDS Version : 10.2.1
Tempobox Version (content_service): 10.1.0
2015-02-04 16:56:08.795 WARN com.opentext.otds.client.OtdsClientBase -
initializeConnectionWithRetry(): Connection failed to initialize.
javax.xml.ws.WebServiceException:
Method validateTicket is exposed as WebMethod, but there is no
corresponding wsdl operation with name validateTicket in the
wsdl:portType{http://v2.services.otds.opentext.com/}OtdsWebSvc
2015-02-04 16:56:08.795 ERROR com.opentext.otag.auth.OtdsInstaller -
com.opentext.otds.OtdsException: javax.xml.ws.WebServiceException:
2015-02-04 16:56:08.796 INFO
com.opentext.otds.client.OtdsRichClient - OtdsRichClient closed
(http://ecmarchdev.corp.bharatpetroleum.com:8080/otds-
v2/services/authentication?wsdl)
What could be the issue?
Thanks.
Ashvini
Ashwin, are you able to connect to the following services from the AppWorks Gateway server?
Member Services:
http://OTDSServer:port/les-services/services/MemberService?wsdl
OR
http://ContentServer/cws/MemberService.svc?wsdl
Authentication Services:
http://OTDSServer:port/les-services/services/Authentication?wsdl
OR
http://ContentServer/cws/Authentication.svc?wsdl
Hi Pradeep,
Thanks for your response.
Yes, both OTDS URLs (Member Services and Authentication Services) are accessible from AppWorks Gateway server.
What could be the reason of following error?
Actually AppWorks Gateway is trying to access following OTDS URL and giving above error. We are stuck here.
http://OTDS:8080/otds-v2/services/authentication?wsdl
-Ashvini
Hi Ashvini,
OTDS 10.2.1 does not seem meant to work with AppWorks 1.1.6.
Regards, Andre
Thanks. You have pointed correctly. It requires OTDS 10.5.0 Patch 2.
Statistics
Related categories
Related tags
Your answer
