Status: Open
Status: Answered
Status: Closed
Status: Duplicate
Unicode in Tempo Box
Posted Jun 25 by Vladimir Komov.
Hello
I develop application and name of application russian word "?????????"
In TempoBox name application is ?????????‡?µ??????
Help me, What can i do to see name "?????????" in my Tempo Box
Hi Vladamir -
Can you confirm some details for me? Was the application that you developed an AppWorks application that you have deployed into the OpenText Tempo mobile client? Is it the name on the application landing screen that is not displaying correctly in Russian? Perhaps a screen shot might help.
Best Regards,
Curtis Mutter
enter image description here
That appears to be an older version of the Tempo App. Can you download the latest version to your device and retry?
Nothing changed.
Notification and Settings has translated and viewed correctly
But my Apps - Nothing changed.
my app.properties
# Required fields
  displayName=?????????
  description=?????????
  releaseNumber=1
  minimumClientVersion=1
  isAvailableOffline=true
   # Make sure the type is an app!
  type=app
If i user "window.otag.auth.firstName" in app, It is not viewing correctly
May be issue is in appworks gateway.
Hi Vladimir,
What version of the gateway are you currently using?
Also does the app name appear correctly when viewed via the Gateway applications view?
Best Regards
Chris
Can You create simple app with russian name?
Then open it on your andriod device. Name will be correctly?
my app.properties encoding utf-8.
in DataBase also names is correctly
Hi Vladimir,
I will ask one of the team to take a look into this, it may be there is a bug that will need resolving for the next release.
Best Regards
Chris
Hi Vladimir,
We've reproduced this issue internally as OTAG-2786, this issue only affects the Android runtime at the moment. iOS and BlackBerry are not affected by this issue and display UTF-8 characters correctly.
Many thanks
Jonathan
Hi Vladimir,
We plan on fixing this issue in our new Android runtime app which is scheduled for release March / April 2016
Regards
Simon
Statistics
Related categories
Related tags
Your answer
