Status: Open
Status: Answered
Status: Closed
Status: Duplicate
How to add 'Add', 'Copy', 'Move' etc to composite view of documents from CS
1
Posted Jun 30 by Anthony Miller.
Updated Jun 30.
I've been tasked with quickly creating a view that looks like this:
enter image description here
I've tried a couple of options using a demo.html file that does the onReady function etc. I don't seem to be able to get the buttons to show at all.
I'm using a simple approach in the onReady function as follows:
csui.onReady( function() {
    // Create the server connector for the widgets.
    var connector = new csui.util.Connector( {
          connection: {
            url: "http://localhost/otcs/llisapi.dll/api/v1",
            supportPath: "/img",
            credentials: {
                username: "Admin",
                password: "livelink",
                domain: "" // optional
    // Create the container browsing widget.
        browser = new csui.widget.FolderBrowserWidget( {
          connector: connector,
          placeholder: "#folderBrowser"
    // Display the container browsing widget.
    browser.show();
Addendum: I tried the approach that listed on the KC as follows but this doesn't seem to work and produces script errors if I try to include model/containernode)
  // connection
      connection: {
        credentials: {
                username: "Admin",
    // container
    var container = new csui.model.ContainerNodeModel(
      { id: 2000 }, { connector: connector } );
    // populate container nodes with actions on reset
    var actionsHelper = new csui.util.ContainerActionsHelper( container );
    // menu
    var menu = new csui.widget.ContextMenuWidget();
    // position
    position = { my: 'left top' };
    // node and actions
    var node = container.children[0];
    var actions = node.actions;
    // show
    menu.showMenuAt( actions, position);
I'm wondering if I am not including a particular reference somewhere, but I'm afraid I am stuck at present, so any help is gratefully received.
Grateful for your help in advance,
Anthony
Statistics
Related categories
Related tags
Your answer
