Status: Open
Status: Answered
Status: Closed
Status: Duplicate
Error while connecting to AW Gateway
Posted Mar 11 by Glen Saldanha.
hello All.. i have installed Aw successfully and i have created a close loop between my phone and laptop. i have installed the AW on my VM which also contains Process and Content Suites.. Using the Appwork client, i can connect to the AW gateway however i get the following error.. 'The URL x-tom // is not a trusted referal site. Please contact System Administrator". The gateway log file and otds log files do not show any specific errors however displays that the user i used including otag has been successfully authenticated. I am wondering if i missed any settings.. i m not using any SSL…
Any suggestions would be helpful.. Thanks…
Hi
If you look in the OTDS admin ui what do you have under the trusted sites section ?
do you have x-otm listed there as a trusted site?
Simon
Thanks Simon. i do not see any x-otm listed… my server name is http://innovate:18080.. how will this translate in context of x-otm.
To be honest, i have heard of this protocol..
To be honest, i have not heard of this protocol..
Hi
It is a request uri used by the mobile client when it is carrying out oAuth 2 auth with OTDS and needs to be added
The x-otm uniquely identifies the std AW mobile client to OTDS
oAuth 2 auth is the default auth flow used by Aw mobile clients and server
Content Server dont support oAuth at present so you can disable the oAuth via the AppWorks gateway settings page and just use either OTDS ticket or plain username and pwd
S
hi,
I have doubt like what should be given in the server address in the AW mobile client(android)
Statistics
Related categories
Your answer
