Status: Open
Status: Answered
Status: Closed
Status: Duplicate
CORS issue on URL: api/v1/nodes/<id>/versions/<version number>/content
Posted Dec 06 by Daniel Godard.
I'm presently receiving a CORS error message when trying to retrieve the content of a document through the CS 10.5 rest api with javascript. The weird part of this problem is that all other CS 10.5 rest api calls are presently working in my test case. Also when using postman to test the get content call it works correctly. Any ideal on how to troubleshoot this issue?
Hi! did you solve the problem? some tip? thanks!
try to add trusted server http://youropentextserver/OTCS/cs.exe?func=admin.securityvars
Statistics
Related categories
Related tags
Your answer
