Status: Open
Status: Answered
Status: Closed
Status: Duplicate
AppWorks Android Build (Not Compatible)
Posted Nov 27 by INACTIVE Kevin Leclair.
The new AppWorks app does not seem to be compatible on my android Samsung Galaxy (http://www.samsung.com/us/mobile/galaxy-tab/SM-T210RZWYXAR-reviews) running version 4.1.2. Any idea when this will be resolved?
enter image description here
It has something to do with Cordova, which is built into our clients. This doesn’t allow it to be installed on an Android tablet. We’re looking into it, but we may need to build a separate tablet version.
Werner,
Thanks. Please keep us posted - as we have a need to support android tablets.
1
Hi Kevin,
Until the application is updated to allow downloads on tablets through Google Play, you can download it directly to your device from our downloads section here. It should install/work fine on your tablet. We have resolved the issue where the download would fail on Android devices.
Thanks!
Thanks Benjamin.
1
This issue has been resolved with the release of AppWorks version 1.1.5. You can now install AppWorks from the Google Play Store.
Statistics
Related categories
Related tags
Your answer
