Status: Open
Status: Answered
Status: Closed
Status: Duplicate
Oracle Notification Integration
Posted Feb 11 by Walter Jones.
We would like to integrate Opentext ECM with oracle notifications… the specific functionality required would be to access a document stored in ECM from a notification.
Has anyone achieved this… if so how, or is there an Opentext solution available?
Thanks
for your assistance.
Hi Walter,
This developer network is specifically for AppWorks, our new Enterprise Application Development and Management platform, I will try to find someone in the organisation to answer your question.
Werner
Hi Walter.
Are my assumptions correct?
I assume you mean that Oracle Notifications monitors the Content Server database and triggers notifications based on the event in the Content Server tables?
These notifications then should reference or retrieve and send a document from Content Server as attachment?
Would that be the document releated to the event or a 'standard' document.
Regards,
Roel
Statistics
Related categories
Related tags
Your answer
