Status: Open
Status: Answered
Status: Closed
Status: Duplicate
Case insensitive filter on MBPM Custom List
Posted Apr 08 by Alessandro Castaldelli.
Updated Apr 08.
How can I use a filter in a MBPM custom list in Case Insensitive mode?
I want to use "Contains" filter but without matching the case of the filtered string.
It seems that all the filters on custom lists are case sensitive.
I'm using MBPM 9.2.1.4 on Oracle Database.
thanks
1 Answer
Alessandro, thank you for your time. I think this is more to do with the database. I just tested this on SQL Server and it worked in case insensitive and I got both the results, in small as well as capital. Whereas on Oracle, it worked in case sensitive mode. SQL Server database I tested on was case insensitive. I hope this helps.
Statistics
Related categories
Related tags
Your answer
