Status: Open
Status: Answered
Status: Closed
Status: Duplicate
REST API How does /nodes/{id}/actions work?
Posted Nov 11 by Me Ra.
Could someone give me examples of how 'actions' work in the REST API? For example, if I need to download a file, is the action '/otcs/cs.exe?func=ll&objId=101197&objAction=download' supposed to give me the url that I need to make the call for a download?
1 Answer
1
This resource returns the actions - classic CS UI pages - registered for the particular node in OScript. Basically, they are the items from the context menu, which you know from the classic CS UI.
You can use this response to check out, what actions are allowed on the particular node, for example. But the URLs are not be accessed by a pure REST API client.
Statistics
Related categories
Related tags
Your answer
