Status: Open
Status: Answered
Status: Closed
Status: Duplicate
Configure TempoBox with HTTPS connection
Posted Jan 28 by Remon Medhat.
We have TempoBox deployed and the url of the tempoBox is Aliased , We configured TempoBox to work with HTTPS connection , so whenever we add apps/bundles we go to the database and change the default hostname of the deployment from the hostname of the machine ( http ) to the aliased HTTPS one.
Now when we try to remove the http port from the server.xml file , tempobox don't work. we found that the connection to the hostname in the "GatewayNode" Table in the DB is the http hostname of the machine . whenever we try to change it,it reverts back after restart. All we need is to remove any http connection and work with https connections only.
any help is much appreciated .
Statistics
Related categories
Related tags
Your answer
